1
This discussion topic has been answered Discussion topic: Help needed with connection to WiFi
This message was authored by: Lindseybenz
The WiFi password is not working and the box has already been reset
Re: Help needed with connection to WiFi
@Lindseybenz
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
@Lindseybenz
