5
This discussion topic has been answered Discussion topic: Having consistent issues with connection dropping - Sky app says no issues
This message was authored by: JordanRehill
Connection consistently dropping - I've checked the Sky App but apparently there are no issues. Router stats attached. Thanks
This message was authored by: jamesn123 Answer
Re: Having consistent issues with connection dropping - Sky app says no issues
Hi @JordanRehill
Your stats do show that your line is dropping so there is an issue. Is your router connected to the master telephone socket using the supplied adsl cable from Sky and microfilter if applicable?
I am NOT a Sky Employee
Hi @JordanRehill
This message was authored by: Diana4
Same here. WiFi keeps dropping out. Very annoying as I work from home for NHS
@Diana4
If you want help please make your own thread, jumping on someone elses is not helpful
Avatar for JordanRehill
Yep connected to the master socket using all Sky provided cables. It's strange as the Sky App is showing no issues with my WiFi or the broadband despite the internet dropping every 2 minutes. Any help/guidance on what to do next would be great. Thanks
@JordanRehill
Next step would be to call Sky and hopefully get them to send Openreach out
