03 Jun 2022 05:02 PM
Good evening,
do you know, if I can change my delivery adress for a new hub? Thank you
03 Jun 2022 05:23 PM
Posted by a Superuser, not a Sky employee. Find out more@SuzieBARRIs this because you will not be in to pick it up?
03 Jun 2022 05:25 PM
No. It's a hub for holiday let. So when it arrives, there will be guests and not us. So I want it to be send to my house, so I can take it with us, when we go there.
03 Jun 2022 05:29 PM
Posted by a Superuser, not a Sky employee. Find out more@SuzieBARRI am not sure if that will be possible if it is not within the same area, as Sky normally say it only goes to the address that the service is being delivered at, but you might be able to re-direct it to the nearest sorting office of the home let and be able to collect it then.
But if you can check with Sky in regards to this yourself, they may be able to send it to you at your home address as being the account holder.
03 Jun 2022 05:32 PM
Thank you. I'll contact them on Monday
03 Jun 2022 05:54 PM
Posted by a Superuser, not a Sky employee. Find out more@SuzieBARRWhen it the service there supposed to go live or the router is supposed to be delivered?
20 Apr 2023 09:42 PM
@Gary+Youngson you'll need to call Sky to enquire about changing the address as this is a customer to customer forum, you are not speaking directly with Sky.
