29 Oct 2022 02:59 AM
Hopefully someone can help...!
I'm a teacher and using all my data to get things done, not happy!
Sky broadband won't connect to some devices via wifi. I've tried so many things and read so many discussions but I can't find anything else to try (that I understand!) I'll try to give as much info as I can
- issue for over 2 days now
- sky broadband check says all is fine
- all green lights on router
- no changes to sky package or router for years
- wifi connection to sky q box working
- wifi connection to sky q mini working
- wifi connecting to Amazon Alexa device
- wifi connecting to Hive device
- wifi connecting to one iPad 8th gen
- WILL NOT CONNECT to iPhone 11, iPhone SE, iPad Pro, iPad (only few years old)
- password has never been changed
- keeps saying password incorrect
have tried...
- restarting router (turning on/off)
- resetting router (reset button on back)
- resetting settings from sky q settings page
- forgetting network info on all devices
- full network settings reset on all devices
- no updates are needed on devices
- tried manually inputting settings from the working iPad
PLEASE can someone help because it's ridiculous and I don't know what else to do?
paying for sky broadband and having to use my phone data to post this and do anything else isn't right.
is it a router issue or an Apple connection issue? But why is one device connecting and others aren't?
thank you in advance 😩
29 Oct 2022 07:53 AM
Posted by a Superuser, not a Sky employee. Find out more@jellee1 normally you should be able to share the wifi password between Apple devices by bluetooth without entering passwords see https://support.apple.com/en-gb/HT209368
certainly works for me I log one phone into a new wifi nnetwork when travelling and share it with my wife;s phone and iPad as well as my own iPad.
Given the list of things you have tried it should have worked. Given other devices are connected it is unlikely to be an issue with the hub all I can suggest is to tell each device to forget the network and then restart the device - each ios device can have different methods of doing that but by restart I mean fully powering down and restarting with the Apple logo showing. Then trying the technique above. .
11 Mar 2023 02:07 PM
I'm also having an issue with some devices (e.g Kindle and Epson printer) ..were perfectly ok connecting to Sky Router Wi-Fi until recently and now just will not connect. No changes have been made to devices/router.. totally frustrating why these won't connect, especially WiFi printer.. when other devices such as iPad, laptop, TV etc are all fine.. Any suggestions greatly appreciated
26 Apr 2023 10:14 AM
am having the same issue with my printer and ring doorbell both of which worked with my previous router. Have spent time with sky support who tell me nothing is wrong with my router however I can get them to connect to my neighbours router with no issues (obviously I cannot continue this). Am looking to leave Sky unless this can be sorted
27 Apr 2023 10:27 AM
Posted by a Superuser, not a Sky employee. Find out moreHI @KevinUlrike
Have you tried splitting the WiFi bands on your router?
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
27 Apr 2023 10:44 AM
The ring doorbell not connecting is possibly related to an issue at Sky starting yesterday morning. Basically, your ring doorbell is connecting to your wifi, but because of the Sky network problem, it can't connect to Ring 'HQ' so the process of setting it up fails. See: https://helpforum.sky.com/t5/Broadband/Sky-Broadband-Routing-Issues-Today/td-p/4293675
