Discussion topic: HELP!!!! Broadband issues
This message was authored by: TPO1
Message posted on 01 Jul 2026 09:04 AM
Transferred broadband to Utility Warehouse on 6th May and have had no end of issues - having to reconnect daily and often several times daily. UW say it's an issue since SKY updated at beginning of May. Any advice?
This message was authored by: daveNOS
Find out more
Message posted on 01 Jul 2026 09:58 AM
Re: HELP!!!! Broadband issues
@TPO1 If you are with Utility warehouser for your broadband then its not a Sky broadband issue, so im unsure as to why you've posted in this section?
You might want to repost your question in the relevent SkyQ, Stream or glass section(depending on which TV service you use) where you may get help or advice.
