8
This discussion topic has been answered Discussion topic: Going full fibre
This message was authored by: gray100
Going full fibre
Openreach are due to connect up our full fibre connection on Friday morning and we already have our new hub. How do we find out when the new connection will go live?is due to connect our full fibre connection on Friday morning,
Avatar for gray100
This message was authored by: gray100 Answer
Re: Going full fibre
Due to be done on Friday
This message was authored by: Doc5907
@gray100
It can go live at any time during the day of activation (mine went live at 11am). You should get an sms when it active.
Sky Q 1TB UHD
LG TV
Sky Mobile
Has both the outside (CSP) and inside (ONT) installation work been completed?
Avatar for gray100
@gray100
If you mean the installation work is due to be done, then clearly activation cannot happen and data won't flow before the physical circuit is completed.  After that it may take up to midnight for internet access to be possible.
Avatar for gray100
As I understand it Openreach do the cabling etc on Friday and then wait for a message from Sky to say it's now live, is that correct?
This message was authored by: loverboi
min went active 5 minuites after he connected it up while the connection synced 🙂 😄
@gray100 normally the engineer will connect one of your devices and demonstrate the connection as part of the installtion visit. However it has been observed that for faster connections like the 900Mb/s the full bandwidth can take few hours to become available.
Avatar for gray100
Unfortunately, the engineer we got was useless to put it politely! Luckily another turned up to do a neighbour's connection a few hours later and solved several problems for us. Because router was moved to a different part of the house had to wait until a new wifi card arrived before everything settled down.
