Discussion topic: Full fibre
This message was authored by: Sharonc3
Full fibre
I have just signed up for sky stream and full fibre 500mg im sure but still have blimd spot in ome of my rooms any help would be great should i call sky not sure what to do if anyone can help thank you
Re: Full fibre
@Sharonc3 increasing speed of yge service to your hub wont solve issues with poor wifi in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
