This discussion topic has been answered Discussion topic: Full fibre broadband
Message posted on 25 Jan 2025 06:51 PM
I have recently spoken to Sky about renewing my contract. During the call I was told I could now have full fibre broadband. After lengthy discussion I realised that If I agreed, OpenReach would turn up , no appointment, no consultation, and take the fibre from the nearest junction, which for me is in a telegraph pole on my neighbours land, and put the box on my wall where they wanted. This means I then have a sky engineer turn up and take it into the house at that point, so my router and phone location would basically be decided by an OpenReach engineer without my input. I have declined this upgrade. Surely I can
discuss where I want things attached to my house. The phone line currently runs to an upstairs wall then through the loft, down the rear wall then into the office downstairs. A modem in the front upstairs bedroom is not what I want.
Has anyone else had issues with this ?
Message posted on 25 Jan 2025 08:10 PM
Putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
It's the two text lines below the table which are most useful.
Message posted on 25 Jan 2025 07:09 PM - last edited: 25 Jan 2025 07:24 PM
Re: Full fibre broadband
@Janeyjenkins wrote:
Surely I can discuss where I want things attached to my house. The phone line currently runs to an upstairs wall then through the loft, down the rear wall then into the office downstairs. A modem in the front upstairs bedroom is not what I want.
Typically an optical cable arriving overhead will run all the way down the outside of an external wall to ground level, where it ends at the external Customer Service Point (CSP) enclosure.
It's then spliced to an optical pigtail which enters the property through a newly drilled hole and plugs into an Optical Network Terminal (ONT) on the inside of an exterior wall of a ground floor room.
They won't bring the optical cable into the loft and down internal walls / through floors, but the optical pigtail from CSP to ONT can potentially run around the outside of a building at just above ground level if there's a clear route for twenty metres or so before coming inside.
Realistically the aim of the national project to hit 85,000 new installations every week doesn't allow for pre-installation survey or much negotiation over cable routes.
Message posted on 25 Jan 2025 07:56 PM
What would they do if the point the cable meets the house is above a sloped roof and the wall directly below is a full height glass window?
Message posted on 25 Jan 2025 08:07 PM
Arriving over a lower roof is a problem for ladder access. Without that they'd probably run around at a high level to a point the cable can come down the outside of a wall
