Discussion topic: Internet not working *again*
Message posted on 25 Jan 2025 07:57 PM
Hello,
We are experiencing issues yet again with our Sky broadboand. It is not working at all but when running tests- it says it's 'looking good'. It isn't. I am completely frustrated now and would like to request a call back to actually speak to someone to raise my concerns and for this to actually be looked at. As a result of this complete misfortune we keep having I am considering completely leaving Sky and starting fresh with a new provider.
Can anyone please advise urgently. I would like to agree with most and say its weather related but this is nearly happening every month and I simply do not have time to keep sorting / chasing solutions to something that should work absolutely fine.
Message posted on 25 Jan 2025 08:05 PM
Re: Internet not working *again*
Sky won't call you back. If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
The lines will be particularly busy at present due to the damage and disruption caused by Storm Éowyn.
