Discussion topic: Full Fibre Upload Speed
This message was authored by: Prichie
Is there a minimum guaranteed upload speed on Sky Max Full Fibre 150 ? As i can't get more than 3.9mbps
Re: Full Fibre Upload Speed
@Prichie
There's no guarantee, but it should be around 30Mbs (over ethernet, not WiFi)
Avatar for Prichie
Thanks for the reply, Ok great stuff I thought with Max Hub the WiFi was minimum 25mbps from 3mbps, maybe I'll try connecting direct to the hub as upload quiet a lot
