Discussion topic: Full Fibre Uograde
This message was authored by: Yondan
Full Fibre Uograde
Are sky doing full fibre upgrades to properties and what is involved, had a call stating they are phasing out copper cabling, at present my property is supplied via an old BT copper cable, so how is full fibre being installed?
Re: Full Fibre Uograde
@Yondan
Sky, like the majority of ISPs, doesn't install cabling: it uses either the national Openreach network or the less widespread CityFibre infrastructure.
If either of these has optical infrastructure in the area, an order can be placed with Sky.
Full-fibre is a new optical cable to the address (either underground or from a pole) and then a new length into the building, typically through a new hole.
There's an additional item of powered equipment (the Optical Network Terminal) required next to the ISP router.
