Discussion topic: Full Fibre Install Tavern lane
This message was authored by: John6000000
I have waited and waited for fibre to be installed for numbers 1 - 12 tavern lane but nothing 13 onwards oh yes they got it
how bout  us poor chaps in berween
im with sky and just want a cheaper price full fibre please
Re: Full Fibre Install Tavern lane
@John6000000
Sky and other ISPs don't get to choose (or even influence) where, when and how Openreach deploys full fibre infrastructure.
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Avatar for John6000000
Yes i have checked on the site you provided but here is the reply i got
FTTP is not available from that exchange
(removed)
Moderator note: Removed personal/identifiable details
Also ive wirnessed a company blow out purple concuit 2 times to plugged them ready but still no luck
@John6000000
Unfortunately it's in the less than tender hands of Openreach then. Sky cannot exert any pressure on behalf of its own existing or prospective customers in a particular location: that's just how the national infrastructure rollout works.
It is possible this was an Altnet installing fibre in the area such as Virgin Media, City Fibre etc.  That being the case Sky would not be able to use their infrastructure.
That was a very good reply
thankyou
regards
john
@John6000000
If the checker states that FTTP is not available at your exchange then it might be that houses after number 12 are connected to a different exchange then houses 1-12.
I am NOT a Sky Employee
Another good answer well thought out
many thanks
john
This message was authored by: mormegil
That is very weird that the whole street can get gfast but only half can get fttp!
at least you will have the option of an alternative ultra fast product for a bit of a boost until openreach decide to do the rest of the street
