24 Sep 2023 08:40 AM
I've had my gigafast for nearly 2 weeks now and started having issues after a week.
Connection issues with q box and mini box which are hardwired and lower WiFi speeds.
I've seen that sky have had issues which may be affecting me also.
This is a concern as my connections drop often or won't connect through WiFi and rebooting the box a few times a day gets it working but then drops again.
My wife has to disconnect her Ethernet and revert to WiFi as her laptop won't load also trying to stream a movie last night caused several bufferings during viewing, not good going by my speeds.
I currently have 2 - 8 port switches and 2-5 port switches which al worked fine on my Vodafone fttp and not so good with sky.
26 Sep 2023 11:17 AM
Posted by a Superuser, not a Sky employee. Find out moreAre any of the switches managed? The Sky hub does not play nicely with managed switches
26 Sep 2023 11:19 AM
They are all unmanaged switches.
26 Sep 2023 11:35 AM
Posted by a Superuser, not a Sky employee. Find out moreOkay, even still it might be worth you unplugging all the switches and starting with one device then going from there. Just see if that makes it stable or not.
Can you also post your router stats?
