Discussion topic: Freezing ads
Message posted on 09 Mar 2026 04:41 PM
Freezing ads
Message posted on 09 Mar 2026 04:47 PM
Re: Freezing ads
Is this on Sky Stream or Glass ?
Message posted on 09 Mar 2026 04:49 PM
Re: Freezing ads
It's freely tv run from my Internet
Message posted on 09 Mar 2026 04:54 PM
Re: Freezing ads
@Sonia14 if programming is running normally and only the ads freeze it is unlikely to be down to your broadband so take up wth Freelly. If both ads and programmes freeze it is likely to be poor WiFi connection to the devicecyou are using to stream.
Message posted on 09 Mar 2026 04:56 PM
Re: Freezing ads
So it's the tv does that mean it's faulty?
Message posted on 09 Mar 2026 05:04 PM
Re: Freezing ads
@Sonia14 no its likely to be an issue at Freely's end where the system they use to inject ads isnt working properly.
Message posted on 09 Mar 2026 05:34 PM
Re: Freezing ads
Thank you been in touch with freely and they dont know either
Message posted on 24 Mar 2026 04:55 PM
Re: Freezing ads
For me it's on Sky Glass particularly playback channel five
Message posted on 24 Mar 2026 06:20 PM
Re: Freezing ads
Which is unrelated to OPs post as they have Freely.
If you are having issue with Glass you need to raise a post within that board rather than adding to an unrelated thread.
