1
This discussion topic has been answered Discussion topic: Fibre
This message was authored by: Bone30
Fibre
Fibre 300 installed Wednesday absolutely rubbish, fire stick keeps losing connection in other rooms, ring cameras keep saying no connection, soon as I walk outside signal lost. Wished I'd kept super fast.
Re: Fibre
@Bone30 the switch from partial to full fibre is not your problem which is likely to be either the change in location of your hub has altered the WiFi coverage or you have Sky Q boxes the loss of their WiFi hotspots with a change to the white Sky Max hub. Do either of those apply?
If the former you can buy a longer Ethernet cable to connect the hub to the new ONT so the hub can be moved to a better position. The latter is something Sky dont explain but in either case buying Sky's WiFi Max bundle should get you at least one extender.
Re: Fibre
