Discussion topic: Fibre broadband
Message posted on 13 Nov 2025 07:20 PM
Fibre broadband
Message posted on 13 Nov 2025 07:25 PM - last edited: 13 Nov 2025 07:27 PM
Re: Fibre broadband
All current Sky Hubs have a WPS button, but it may not be obvious. Which model do you have?
Message posted on 13 Nov 2025 07:29 PM
Re: Fibre broadband
SR203. Engineer came through the week set it up then left. Then I realized wifi wasn't connected to TV, and no apparent wps button. A button which says reset, but nothing happens when you push it in. Thanks for responding.
Message posted on 13 Nov 2025 08:25 PM
Re: Fibre broadband
@RubyMac72 Right Hand Side edge off the SR203 1 inch from the bottom, you will see it, when you press it in orange light in the button will come on!
