Discussion topic: Internet not working
This message was authored by: Jmac9
We have followed all instructions to unplug and reset etc but WI-FI is still not working on all devices
Would it be possible to book an engineer
Re: Internet not working
@Jmac9
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
