3
This discussion topic has been answered Discussion topic: Faulty streaming ever since the switch to full fibre
This message was authored by: Hillytwo
Since my switch to full fibre instigated by Sky, the streaming service in my house is rubbish, constant error messages, weak WiFi around the house and generally just disappointing, I constantly restart the router and TV s but repeatedly get the same problem, I am at a loss to understand it. Help!!!!!
Re: Faulty streaming ever since the switch to full fibre
@Hillytwo often thecswitch to fibre means the hub will have been moved which can affect the WiFi signal levels in other rooms. Ideally the hub should be as central as possible on a surface so it is out in the open above obstructions like radiators. If you need a longer cable to connect the hub to the ONT unit you can buy a srandard Ethernet cable. There sre other possible causes if you have Sky Q tv boxesxand now have a white Sky hub.
However the best advice is to get a booster which can come as part of he WiFi Max package see https://www.sky.com/help/articles/sky-wifi-max
This message was authored by: Deborah+Dcruz
I have the same problem NO SKY
Avatar for Hillytwo
I've got the booster package that I am paying for, very disappointed in Sky, I've been a customer for 23 years and they just don't give a [Removed]
Moderator notes: Removed foul language
