3
This discussion topic has been answered Discussion topic: Falkirk area outage
This message was authored by: EdwardCh
Falkirk area outage
Interested hug anyone in the Falkirk area also has broadband outage ? Sykynsaying everything ok, multiple neighbours are offline and thinks it's a BT issue. Wondering if anyone else has information
Re: Falkirk area outage
@EdwardCh
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for EdwardCh
That should read "How interested if anyone...
@EdwardCh
Avatar for EdwardCh
Thank you for the suggestion, it turned out to be an open reach failure
