Discussion topic: No broadband
Message posted on
15 Apr 2026
07:06 AM
- last edited:
15 Apr 2026
07:49 AM
by
Nimbob
No broadband
There's no broadband [Removed] PLEASE FIX THANK YOU
Moderator notes: Removed personal info
Message posted on 15 Apr 2026 07:28 AM
Re: No broadband
@LesterJHolloway
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Your post has been temporarily removed as you've posted the majority of your home address on a public forum. The post should reappear after moderation later.
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
