Discussion topic: hub wont connect
Message posted on 10 Jun 2026 07:29 PM
hub wont connect
my sky hub wont connect to the internet nothing is going on localy everything is in green but my hub just keep slowly lights in green ???
Message posted on 10 Jun 2026 07:30 PM
Re: hub wont connect
@lukasf First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 10 Jun 2026 07:35 PM
no outage at all it just says my hub wont connect to the internet
Message posted on 10 Jun 2026 07:39 PM
hub wont connect it says it cannot find it it isnt even responding
Message posted on 10 Jun 2026 07:57 PM
If the test you ran hasn't found a fault and all the lights are lit as usual then try a reboot of it at the mains.
Message posted on 11 Jun 2026 03:39 PM
How do I do a hard reset ? By switching it of the mains ??
