7
This discussion topic has been answered Discussion topic: FTTP upgrade - "Conversion kit"
This message was authored by: Resident1
Hey,
Just ordered the upgrade to FTTP and was told I'd be sent a 'conversion kit' for my router.
What's arrived is just a short Cat5e ethernet cable.
Is that it?
If so I wish they'd have said, I've a drawer full of ethernet cables and the one they've sent isn't going to reach.
Re: FTTP upgrade - "Conversion kit"
@Resident1
Where a subscriber is already using a Sky Broadband Hub or Max Hub for FTTC or ADSL, the 'conversion kit' facilitates connection of the WAN port (eth #4) on the Hub to the ethernet port on the ONT to receive FTTP.
ISPs always supply whatever they consider to be a standard length cable, and it's up to the customer to source a longer one if needed.
@Resident1
Avatar for Resident1
Level 2 icon
Thanks for that reply.
Sorted through my drawer of cables and found a Cat7.
Over kill for any home network but it'll be well within any limits.
This message was authored by: PP39
Where you get ONT from
@PP39 the ONT is supplied and fitted by the engineer when installing a full fibre connection.
@PP39
Unless an existing ONT has inadvertently been removed by the previous occupant: in such a case you'd need to call Sky to book replacement by Openreach.  There's hopefully a short length of optical fibre with a green rectangular jack plug left behind.
This message was authored by: Kennyboy633
I wish they had said too... not because I have a longer cable, but because (1) the leaflet implies there should be a "signed for" box not received, and (2) I've just spent ages asking the virtual assistant questions - how ever I phrase my question, it loops back to the first thing I said I didn't want to know about - aah well - irritating.
@Kennyboy633 Generic leaflet help, and sometimes you just got to read between the lines, and the loop when the system does not understand is just unavoidable so to say!
