This discussion topic has been answered Discussion topic: WiFi issues
Message posted on 07 Jan 2026 09:06 AM
My internet works but only certain apps work. Whats app and instagram do not work. I have checked the connection on sky but says it's good. I have checked in multiple devices and it is the same on all.
Message posted on 07 Jan 2026 09:15 AM
Hi @Rahima27
It sounds like you may need to change your Sky Shield settings.
https://www.sky.com/myaccount/bb-and-talk/broadband-shield
Hi @Rahima27
Message posted on 08 Jan 2026 02:13 PM
Re: WiFi issues
Thank you it worked. Strange as I've had sky internet for a few years and have never changed any settings.
Message posted on 08 Jan 2026 03:00 PM
Re: WiFi issues
@Rahima27 Been a few oops on the old broadband shield, you just never know but worth checking it from time to time, you can jump about on it and as long as no save is applied it does seem to behave, might have been a reset, or it just never worked for you and kicked itself into life!
