Discussion topic: FTTP 500Mb getting 90Mbps and router keep dropping connection
This message was authored by Fenderbender22 This message was authored by: Fenderbender22
I've had this router dropping connection for about a year now, and recently I started to have this issue with my speed being capped at around 90Mbps, where I've been getting over 500 at all times wired and wireless.
Here is the log from the latest dropout. Can anyone help point out anything obvious?
syslog: [99468.474000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
syslog: eth3.1 - WAN link DOWN.
syslog: DHCP lease expired from server. Connection DOWN.
syslog: [99471.515000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
syslog: [99472.526000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
syslog: Voice IP Connection Down
syslog: [99474.543000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
syslog: [99475.568000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
syslog: Voice Disconnected
syslog: sky dhcpc client (v0.0.1) started
syslog: [99478.612000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
syslog: [99479.630000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
syslog: [99482.676000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 100 mbps full duplex
syslog: eth3.1 - WAN link UP.
syslog: Received valid DHCP lease from server. Connection UP.
syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21121BC000544/6CA0B48039B8/188.221.195.220/7.02.0203.R/2a02:c7c:2ea2:ef00::1]
syslog: bind 0.0.0.0 - Address already in use
syslog: WAN IPV6 UP
syslog: Voice IP Connection Up: 2a02:c7c:2ea2:ef00::1/64
syslog: Voice Connecting
syslog: Voice Connected
I don't have a landline/VOIP phone, and this is what happens all day several times a day, the voice light goes orange, and then the internet drops out. I've rang sky numerous times regarding it, and it's currently with the "network team". I have recently swapped out the router with a brand-new replacement, so it's unlikely to be that. This also happens when I have nothing hard-wired except the wan port.
I could bare the dropouts as I can restart the router and be back online in a few mins, but this is just awful. I have many devices at home and struggling to keep up with the limited bandwidth.
PLEASE PLEASE someone help me.
Fenderbender22
Re: FTTP 500Mb getting 90Mbps and router keep dropping connection
just happened again like 10 mins later
20:51:38 syslog: WAN IPV6 UP
20:51:57 syslog: [101322.238000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
20:51:59 syslog: eth3.1 - WAN link DOWN.
20:51:59 syslog: DHCP lease expired from server. Connection DOWN.
20:52:01 syslog: [101325.276000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
20:52:02 syslog: Voice IP Connection Down
20:52:03 syslog: [101327.297000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
20:52:05 syslog: Voice Disconnected
20:52:06 syslog: [101330.328000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
20:52:07 syslog: [101331.345000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
20:52:07 syslog: sky dhcpc client (v0.0.1) started
20:52:09 syslog: [101333.369000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
20:52:11 syslog: [101335.391000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
20:52:12 syslog: sky dhcpc client (v0.0.1) started
20:52:14 syslog: [101338.416000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 100 mbps full duplex
20:52:18 syslog: sky dhcpc client (v0.0.1) started
20:52:23 syslog: sky dhcpc client (v0.0.1) started
20:52:28 syslog: sky dhcpc client (v0.0.1) started
20:52:31 syslog: sky dhcpc client (v0.0.1) started
20:52:35 syslog: eth3.1 - WAN link UP.
20:52:35 syslog: Received valid DHCP lease from server. Connection UP.
20:52:35 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21121BC000544/6CA0B48039B8/188.221.195.220/7.02.0203.R/2a02:c7c:2ea2:ef00::1]
20:52:41 syslog: bind 0.0.0.0 - Address already in use
20:52:47 syslog: WAN IPV6 UP
20:52:47 syslog: Voice IP Connection Up: 2a02:c7c:2ea2:ef00::1/64
20:52:47 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21121BC000544/6CA0B48039B8/188.221.195.220/7.02.0203.R/2a02:c7c:2ea2:ef00::1]
20:52:49 syslog: Voice Disconnected
20:52:53 syslog: Voice Connecting
20:52:53 syslog: Voice Connected
Fenderbender22
Bit different this time:
16:30:57 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
16:31:02 syslog: bind 0.0.0.0 - Address already in use
16:31:07 syslog: WAN IPV6 UP
16:31:07 syslog: Voice IP Connection Up: 2a02:c7c:2ea2:ef00::1/64
16:31:07 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D21121BC000544/6CA0B48039B8/188.221.195.220/7.02.0501.R/2a02:c7c:2ea2:ef00::1]
16:31:07 syslog: Firmware is already up to date, matches FUS
16:31:09 syslog: TR69: Connect to Production ACS
16:31:09 syslog: TR69: Connection to ACS Complete
16:31:13 syslog: TR69: Voice Line SIP configuration received
16:31:13 syslog: TR69: Close ACS Connection
16:31:14 syslog: Voice Disconnected
16:31:18 syslog: Voice Connecting
16:31:18 syslog: Voice HARDENING
16:31:18 syslog: Voice Connected
16:31:19 syslog: Voice Disconnected
16:31:23 syslog: Voice Disconnected
16:31:27 syslog: Voice Connecting
16:31:27 syslog: Voice Connected
Fenderbender22
Fenderbender22
Nobody? 😞
@Fenderbender22 given you have done all of the obvious things and the issue is with the network team it is difficult to suggest anything more. Assuming the ONT is remaining connected throughout it is logical to assume there is an issue in the Sky network that is causing the problem.
The only advice I can offer is to escalate this to a formal complaint, if you have not done so, with the aim of getting Sky to release you from contract to switch to an ISP better able to provide problem free connection. If you use your connection for business then you may find a provider such as Zen a better choice. This link explains how How to make a Sky complaint | Sky Help | Sky.com
This message was authored by Mr+Slant This message was authored by: Mr+Slant
There's something wrong with the connection between the router and the ONT :
That would explain you only getting 90Mbps or so throughput.
Have you tried another ethernet cable?
@Fenderbender22
Your log shows a constant up and down of ethernet port 4 on the hub which is connected to your ONT therefore the issue is almost certainly either the router/ethernet port, the ethernet cable between the ONT & Router or the ONT itself. Are you able to try changing the cable?
I am NOT a Sky Employee
Fenderbender22
I am actually surprised at this because the ethernet cable hasn't moved since it's been installed and was getting 500 but yeah I changed the cable and I'm getting full speed again. Crazy to me that the cable has just failed.
Thanks guys, hopefully this resolves the intermittent cutting out too
