1
This discussion topic has been answered Discussion topic: Extension cable
This message was authored by: Todo1230_0
Extension cable
Can i use a phone extension lead to move my hub to the centre of the bugalow as the WiFi does not reach the other end of the bungalow.
Re: Extension cable
@Todo1230_0 yes assuming you have a service delivered via a copper line. A continous DSL cable without a join from the master socket to the hub would be preferable as daisy chaining cables can cause speed loss.
Re: Extension cable
