Discussion topic: Receiving Yahoo mail (not Sky Yahoo) on Sky broadband
This message was authored by JohnMac07 This message was authored by: JohnMac07
I upgraded my Sky broadband package in January (to Fibre - Ultrafast 1) and since doing so have had real issues, daily, with receiving my Yahoo email (not Sky Yahoo). I've just put up with it so far, but, this has been emphasised because having just returned from holiday - where everything worked fine - I’m back to the same old problem. (Additionally, everything worked fine on my previous Sky package.) Email will eventually come through but can take a full day of repeated mail 'checking' before it does. I know there has been similar posts on this subject previously, but can anyone help with a solution that works or make any suggestions..? Thank you in advance.
Re: Receiving Yahoo mail (not Sky Yahoo) on Sky broadband
@JohnMac07 your issue is very unlikely to being caused by the Sky broadband connection. Rather it is likely to be either a Yahoo issue or with the app you use to read your email.
JohnMac07
Thank you for response  @Chrisee. Any ideas on how I can improve the situation..? Everything works fine - until I get home to my own broadband..! I don't use a specific email app on either my iPad or iPhone, it's just the email facility that's provided with my yahoo account details. Thank you in advance.
@JohnMac07 check the Broadband Shield settings in the My Sky app as it is possible they are set to low.
JohnMac07
 @Chrisee Yes - did that and have previously tried switching Shield off altogether, as per a suggestion from a previous post, on the same matter. Any other suggestions..? Has anyone else reading this had the same issue and been able to resolve..? Thank you very much, in advance.
