05 May 2022 02:27 PM
Every time I attempt to access Eurocarparts.com i get a message saying that the web site took too long to respond. I have tried from my laptop (ethernet connected) and phone wifi connected with the same results. Other web sites can be accessed ok. If i turn wifi off on my phone and use EE 4G then i can access the site with no issues. The site has worked fine in the passed from my phone and PC. Any help would be appreciated.
Thank you in advance Owen.
05 May 2022 05:16 PM - last edited: 05 May 2022 05:27 PM
Posted by a Superuser, not a Sky employee. Find out moreTry unplugging your router for 20mins to get a new public IP. You may have inherited a bad one
05 May 2022 03:41 PM
Posted by a Superuser, not a Sky employee. Find out more@Owen-666Is the DNS set as default on these devices. Might want to try change those on one of the devices you have to see if you can then access this site.
05 May 2022 03:47 PM
Go to broadband shield on your my sky app and change to 18
@Highlinder eurocarparts rings a bell. It's an 18+ site so possibly a broadband shield job.
05 May 2022 05:00 PM
I have changed the broadband shield from "Disabled" to "18" with no difference so i have changed it back to "disabled"
05 May 2022 05:01 PM
I have also tried setting the DNS to 8.8.8.8 (Google) and the IPV6 to 2001:4860:4860::8888 (also google) again with no effect.
Ah, it was disabled in the first. It should have worked previously then
05 May 2022 05:03 PM
Posted by a Superuser, not a Sky employee. Find out more@Owen-666Where are you changing the DNS at ?
06 May 2022 09:14 AM
Thank you for all the suggestions. The problem was resolved by turning the router off for 20 minutes are restarting it. I assume that this is an issue that Sky need to look at as clearly some of their IP range can not access all websites..
