Discussion topic: Ethernet port speed
Message posted on 22 Apr 2024 10:38 PM
Ethernet port speed
Hello - I have sky WiFi 150mb, which works well over WiFi. I have Ethernet ports around my house however and I'm only getting up to 90mb (according to the Netflix speed app). I've tried connecting a laptop directly to my router but this still only gets between 80-90. I have cat 5e Ethernet cables which should be fast enough. Is there anything in need to be doing differently?
thank you!
Message posted on 22 Apr 2024 10:52 PM
Re: Ethernet port speed
Check the settings of the network interface adaptor in your laptop - it could be set to 100 Mbps instead of 1000 Mbps.
Checking your computer's network interface speed · Customer Self-Service (voyager.nz)
Message posted on 22 Apr 2024 10:58 PM
Thank you! I will check on my laptop, but will that influence the other devices connected via Ethernet? I have my main sky q box and a sky q mini, both of which are showing less than 90mb speed via Ethernet, which is very similar to when connecting a laptop directly to the router
Message posted on 22 Apr 2024 11:27 PM
Not sure. Someone with better knowledge than me will soon reply, I suspect!
Message posted on 23 Apr 2024 12:45 AM
@Sam180 In general, streaming type devices don't require massive amounts of bandwidth, even a uhd video stream is typically 25-30Mb/s max,
so it's common for tv's / set top boxes Ethernet ports to be 10/100 max.
PC's or laptops normally have better specifications, so you should be getting closer to 140Mb/s over a wired connection from the likes of fast or Ookla.
Tom...
BELIEVE =accept that (something) is true, especially without proof.
BETTER = of a higher standard, or more suitable, pleasing, or effective than other things or people:
Sky Q & 2 mini’s
SR203 router. > Replaced with ASUS XT9’s with a TP-Link TD-W9970 modem
Sky superfast 80/20 :sort of, 63-75/15. Devolo 1200 wifi > Replaced with cat 6
Sony KDAF8 65 oled.
Message posted on 23 Apr 2024 08:16 AM
@Sam180 if you ethernet cabelling has been in place for some years it is possible it doesn't support gigabit speeds which requires a minimum of Cat 5e cabelling with all 4 pairs connected. In practice 90Mb/s is ample for most purposes as few apps can use much over 100Mb/s anyway. The one huge benefit of ethernet is it is far more stable than wifi.
Message posted on 23 Apr 2024 09:37 AM
I would also log into your router and check the ethernet ports are set to Gigabit and not Fast Ethernet.
Not a sky broadband subscriber
Message posted on 23 Apr 2024 12:34 PM
Thanks both - it's a new build house so I'm expecting the Ethernet cables through the walls to support over 100mb. I've also checked the settings on the router and it's set to gigafast 😞
agreed that 90mb is ample, I'm just wanting to get the maximum I can through the cables if I'm paying for 150mb!
Message posted on 23 Apr 2024 12:35 PM
Can you send a screenshot of your ethernet status in Windows when you connect your laptop via ethernet?
