Discussion topic: Ethernet cable connections
This message was authored by: WJD2
Hello What does the ethernet cable in the broadband hub do? It connects to my Sky tv box but nothing seems to change on my tv when I unplug it.
Re: Ethernet cable connections
@WJD2
Most Sky+ HD boxes still in use and all Sky Q boxes are capable of WiFi connection.
This message was authored by: Me134
Presumably you're connected via wifi, you can go to the network settings and change it to the wired connection if you have a weak wifi connection to the box.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
