Discussion topic: Ethernet Socket Installation Different Room
Message posted on 14 Apr 2025 11:08 PM
Hi all.
Is there any chance that Sky provides the service to install a socket for ethernet on a different room of the house? It's installed on my living room at the moment, but i need a new socket in the office on the floor above. Is that something that Sky proivdes?
Thank you.
Message posted on 14 Apr 2025 11:18 PM - last edited: 14 Apr 2025 11:21 PM
Re: Ethernet Socket Installation Different Room
@EmanuelSousa Not a service that sky would offer, you would be better to see if there is a local data company or even some ex OR employees that offer an installation service. If you do not require high speed's you can also consider doing a powerline through the mains electric, speed will not be that fast what is say's on the box is NO where near what is provided...
Message posted on 14 Apr 2025 11:35 PM
hi @JimM1 i've tried the powerline, but honestly impossible. The connection is very, very unstable. And i know it's comming from the powerline, because when i was downstairs before, i was fine. I've tried different plugs as well, but the result was all the same. I'll have a look at those companies, see how much will they quote me for then. Thank you for your reply !
Message posted on 14 Apr 2025 11:39 PM
@EmanuelSousa Can happen with powerline over distance and over floors, i use both types and as i say speed is not an issue, and you MUST allways use the mains socket to plug them in, NO EXTENSION sockets of any kind....
Message posted on 14 Apr 2025 11:48 PM
Yeah, i've always done that. I've used the powerline for a few years now, but it was in a flat, so I never had any issues. But know, going one floor up, makes a lot of difference, specially cause the speed in my area isn't great already, so it makes it even worse. I'll see some companie's quotes, otherwise i'll just bring an ethernet cable up with some DIY in a middle!
