Discussion topic: sky broadband outage
This message was authored by: Bigpete1
How do I check my broadband status
Re: sky broadband outage
@Bigpete1
Use the below link to check to see if there are any broadband problems or outages nearby
This should determine if there's an identified fault affecting multiple households.
