14
This discussion topic has been answered Discussion topic: Ethernet Cable
This message was authored by: Scott356
Ethernet Cable
Hello,
My Ethernet cable (yellow) does not fit into the BT box within my house so i cannot get Internet
I bought a RJ11 socket to try and resolve the issue which did not work,
Can anybody suggest anything?
This message was authored by: cookiemonsteruk Answer
Re: Ethernet Cable
@Scott356
A replacement ONT optical network terminal
Re: Ethernet Cable
@Scott356
When are you due to be activated?
Has the ont been installed
If not this fibre modem ont will be installed on the day of activation
Avatar for Scott356
Re: Ethernet Cable
Hello,
Thanks for your help
My activation was Monday, but i do not have a box like that in my house, how do I arrange this to take place?
I have an old looking Phone Port?
Kind Regards
Scott
Re: Ethernet Cable
@Scott356
Are you in the uk
Could you enter your full address below and post the table and notes after removing your address from the image
Just to verify if a ont existed before you
Avatar for Scott356
Re: Ethernet Cable
Thanks again for your help, please see detils below:
Avatar for Scott356
Re: Ethernet Cable
Sorry yes UK resisdent
Re: Ethernet Cable
@Scott356
Ont exists with active service
I think not as the previous occupant has made off with it.  I take it you've moved in?
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
To request a new one. Any issues get back to us
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
Re: Ethernet Cable
@Scott356
'ONT exists with active service' means the property is already provisioned for FTTP: if there's no ONT visible then that's typically because a previous occupant has taken it with them when they moved out.
Re: Ethernet Cable
@Scott356
Try looking for a very thin white cable with a rectangular green jack plug on it, somewhere in the vicinity of a power socket.  There may also be a couple of screws left in the wall, and the white cable may enter the property behind a round white cover.
Avatar for Scott356
Re: Ethernet Cable
Thank you, can i check with you what i am requesting?
Re: Ethernet Cable
@Scott356
Re: Ethernet Cable
@Scott356
You are requesting an ONT (Optical Network Terminal) because the one which should be at the address isn't there.
Avatar for Scott356
Re: Ethernet Cable
Thank you
Re: Ethernet Cable
@Scott356
What you are looking for is something like this:
In some installations the white optical cable will be considerably longer.
Re: Ethernet Cable
@Scott356
Did you get thru to sky ?
