Discussion topic: Eero 6 installation
Message posted on 10 Jul 2024 12:16 PM
Eero 6 installation
Hello - I am a novice at this but have existing Eero 6 that i have set up but exists in addition to Sky Router Wifi because I dont know how to change Sky Q and 2 mini boxes to not need the Sky Router to work properly. When i disable Sky Wifi and switch main box to Eero wifi the mini boxes wont work and pick up signal from main box to operate. Can anyone help? I cant connect sky box via ethernet able to EEro - Router in another room
Message posted on 11 Jul 2024 07:11 AM
Re: Eero 6 installation
A couple of ideas:
Change the Eero wifi network name and SSID to the same as the sky router. The Sky Q may then see it ok and you can then turn off the sky router wifi. You can then restrict the SkyQ to mini wifi network bands to help performance.
https://helpforum.sky.com/t5/Broadband/Sky-Q-main-box-amp-eero-router/m-p/4271601
Otherwise get a second eero and place it so the SkyQ box can be on a wired connection and then do the same with the SkyQ wifi.
Once working make sure you turn off the router wifi.
Message posted on 14 Jul 2024 06:15 PM
Thanks for response I have tried adding a new eero 6 with Ethernet cable to the sky box but sky box won't recognise and keeps connecting to the Sky wifi.
I have tried switching wifi on Q hub and mini hubs but can't access the advanced settings
switch off Ski WiFi 2.4 and 5 has also reduced by broadband speeds on the eero??
confused
Message posted on 14 Jul 2024 07:00 PM
1) Press the ‘Home’ button on your remote control.
2) Scroll down to highlight ‘Settings’ but DO NOTpress select.
3) Press ‘001’.
4) Press ‘Select’
Then: Network -
- 2.4Ghz wireless - Off
- 5Ghz wireless - Off
Message posted on 15 Jul 2024 06:46 AM
Make sure you have turned off the wifi on the router as well.
https://helpforum.sky.com/t5/Broadband/Turning-off-sky-router-wifi/td-p/3889852
Once the sky Q box is working on the ethernet connection, you can re-enable the Sky Q box wifi in the limited bandwidth mode so it talks to the Sky Mini.
Message posted on 15 Jul 2024 10:52 AM
Thank you. All worked ok until I try to use the mini box and they have tried to reset but can't get them connected to the main box on WiFi. Get as far as step 1 press select to connect with WiFi and hangs?
also when I switch the mini box on the main box defaults back to the WiFi connection - assuming cos that is signal coming from mini box??
Message posted on 15 Jul 2024 11:33 AM
Update - one mini has connected on and able to reactivate connection with main Sky q - the other one goes through reset and then gets to step 1 but won't move passed this by pressing Select.
Message posted on 15 Jul 2024 02:01 PM
Although I no longer have a mini box, as a suggestion, maybe try a full reset on the mini box.
Switch the Sky Q Mini box off at the mains.
Hold down the Reset button on the back of the Sky Q Mini box and switch it back on at the mains.
Keep holding it until the light on the front flashes red and green. This will take about 30 seconds.
Once it flashes red and green, press the standby button on the front of the box.
If the lights don't show after 30 seconds, repeat steps 1 to 2.
The box will then restart.
