Discussion topic: Dynamic IP
This message was authored by username182371263 This message was authored by: username182371263
Dynamic IP
I don't know if Sky discloses this information or not but how often does your dynamic ip change and does it also change when your router turns off, eg.  a power outage. Thanks
Re: Dynamic IP
@username182371263
Isp ip addresses are sticky. They usually only change after the hub has been switched off for more than 1/2 an hour
Re: Dynamic IP
@username182371263
Sky uses 3600 second (one hour) DHCP lease times for the external IP address so if the router is switched off or otherwise disconnected for over half an hour a different address may be assigned when it reconnects.
