Discussion topic: Dropping and no connections
Message posted on 28 Jan 2025 08:07 PM
Hi all,
I know I need to ring sky but rather do it during the day.
Sky broadband keeps dropping and losing connection, WiFi is horribly slow, and drops out also.
Just now sky is saying no connection yet all lights are on. Reset a couple of times and gone through the tech processes. Nothing.
it's becoming very annoying.
Might be coincidence but BT where working on their overheards recently and coincides with these issues.
The sky app says everything is ok but it's not.
Any ideas guys?
thank you
Message posted on
28 Jan 2025
08:10 PM
- last edited:
29 Jan 2025
08:51 AM
by
Samraj
Re: Dropping and no connections
(removed) ours is the same and we are fortunate enough to say we never really have problems up until this evening
MODERATOR NOTE: Unfounded allegation removed.
Message posted on
28 Jan 2025
08:17 PM
- last edited:
29 Jan 2025
02:24 PM
by
Samraj
There is no national outage so not sure what makes you think they'll be some kind of announcement.
Message posted on 28 Jan 2025 08:43 PM
Over 20 posts of broadband down within 20 minutes of each other makes you think there could be 🤷🏼♀️
Message posted on 28 Jan 2025 08:45 PM
20 out of millions of Sky Broadband subscribers a couple of days after two intense storms.
Message posted on 28 Jan 2025 08:48 PM
Message posted on 28 Jan 2025 08:57 PM
@Chloe+Mo @Lyndyloo67
The wait for any necessary Openreach visit will still be delayed due to the disruption from the recent storms.
