Discussion topic: Does Asus xd4 work with sky?
This message was authored by: Nel13
I have a house which has ethernet ports in every room. The WiFi from sky router is not very good in most rooms so I am looking for a way to boost the wifi using my ethernet ports.
Can I use Asus xd4 and plug them into the ethernet ports on multiple rooms, and then wire them into the existing sky router?
Avatar for Nel13
Re: Does Asus xd4 work with sky?
Also if anyone has any other suggestions that would be great
