Discussion topic: Broadband went down, been getting 10% of guaranteed speed every since
This message was authored by ir91 This message was authored by: ir91
In the last few days, the broadband has been going down frequently for short periods of time. Yesterday at around 5 PM, it went down for almost an hour and then intermittently every 2 minutes until 9-10 PM. Since it became "stable" (which is a kind way of putting it), I have been getting 10-16Mbps instead of the guaranteed 100-160Mbps. This drop in speed is weird and unacceptable.
I've booked an engineer for Tuesday so we'll see if they can do anything about this.
This message was authored by Canarian1 This message was authored by: Canarian1
Re: Broadband went down, been getting 10% of guaranteed speed every since
My internet is down in london
@Canarian1 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
ir91
My internet has been down again now consecutively for the past 3 hours. Unbelievable
@ir91  Can you follow the directions posted above your post please.
ir91
@Highlinder Thanks, I did and booked an engineer for Tuesday. I just wanted to voice my displeasure with the service since I'm almost 2 full days without being able to properly use my internet and will potentially have to wait until Tuesday to do so.
@ir91  If you have had no service for more than 2 days then you should get a credit on your broadband once it is fixed.
