Discussion topic: Disabling sky hub
This message was authored by: Edith2025
Disabling sky hub
Does anybody know how to disable sky hub as i am trying to host something else on the router ip
Re: Disabling sky hub
@Edith2025 Thevonly way to disable Sky hub is to unplug the power which will of course stop the connection. Not sure what you are trying to do but if it is to use a different router you either need to connect it to the incoming service directly and configure it to manage the connection which cannbe impossible on some models or connect to the LAN connection of yhecSky hub and use it in  a Double Network Address Translation setup.
