Discussion topic: Devices automatically connecting to Sky Max Pod
This message was authored by: DaveStanley1
I wanted to understand if devices will automatically connect to the Sky Max Pod if the signal is stronger than that from the Sky Max Hub? It seems as though you can add a device to your network but you don't have the opportunity to choose which network hub you connect to. The reason I am asking is I have a device that was connected to the Sky Max Hub but the connection has dropped out a couple of times. If I try to reconnect it now I have the Sky Max Pod, will it simply look for a connection with the strongest signal? I hope this makes sense. I have noticed that one device is connected to the Sky Max Hub and I did not manually connect it.
Re: Devices automatically connecting to Sky Max Pod
@DaveStanley1 The devices make the decission as to what they think is the best way to go, whether that be to the hub or to the pod, if they are latched onto the hub, they may just like to stay there, a drop off the device wireless connection say forcing off the wireless on your mobile, standing right next to the pod, turning the wireless back on, it may latch onto the pod, then again as it checks as see's where to go, it may just say hub is there, weaker i do not care, hub is where i am going.....
