6
This discussion topic has been answered Discussion topic: Device WiFi connectivity issues
This message was authored by: dejohnba
Help... having differing issues with WiFi connection depending on which device I'm using. The WiFi is connected without internet on my work laptop (Lenovo). It won't connect at all on my Xbox. It seems to be working fine on mobile phones, now tv stick & Alexa. Connected but not all websites/apps working on my personal laptop.
I've tested the broadband on my sky app and it says there are no issues and the internet is connected.
I have tried turning router on and off and restarting devices/disconnecting & reconnecting to the WiFi but nothing seems to be changing.
Any ideas what the issue could be?
This message was authored by: Highlinder Answer
Re: Device WiFi connectivity issues
@dejohnba  Which router do you have from the link below
This message was authored by: Mon2
I can't get my device connected to messenger or watsapp with  my broadband
Can anyone help
This message was authored by: Karen183
Hi. I'm having very similar problems. Were you able to resolve the issue?
This message was authored by: KateFrench
I have the same issue. Was there a resolution? Thanks
This message was authored by: Jerman
I have done all suggestions and nothing is connecting including sky glass,  alexa and mobile
This message was authored by: puffmcpuff
Having a similar issue.
my work laptop (which connects to an external network ok in work as IT tested it) personal HP printer and work phone not connecting to my new Sky Max router/wifi.
My SkyQ box, personal phones and personal laptop/ipad are ok.
Tried all the reset/trouble shooting advised by Sky and Microsoft. Spoke to my work IT teams who are a bit mystified.  As we all work from home, non company offices/travel etc the WiFi connection ability is in itself is not restricted. And I have not had this problem before with other work laptops and old router.
i am at a bit of a loss! They all can find the network but do not recognise the network security key it seems. As a new Sky max router which I only received at the weekend, I have not changed the password etc.
any ideas?
thanks
