Discussion topic: Default gateway on Sky Max Hub
This message was authored by: MartG1
Hi
I currently have a Virgin Media Hub in modem mode with an ASUS Router connected and set to use address 192.168.1.xxx as I work from home with a VPN and the office network is using 192.168.0.xxx already.
When I move to my new address I will need to use someone other than Virgin. Will the Sky Max Hub let me change the network address to 192.168.1.xx? If not is there a modem mode or a differnt Sky hub tat would allow this?
Regards
Martin
Re: Default gateway on Sky Max Hub
@MartG1  As far as I'm aware Sky hubs operate in the IP range 192.168.0.xx i'm not sure if this can be changed on the Sky Max hub (White Hub)but can be on the broadband hub (black hub).
