Discussion topic: Internet light is orange WiFi & power are green
Message posted on 10 Apr 2025 05:57 PM
Any help most appreciated.
Power & WiFi lights are green on router, internet light is orange
have done all the required tests and saying everything ok
Message posted on 10 Apr 2025 05:59 PM
Re: Internet light is orange WiFi & power are green
@katenobl
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
