Discussion topic: DTMF issues
This message was authored by Cookiemonster13 This message was authored by: Cookiemonster13
DTMF issues
Hi, I am unable to use any services that need dtmf (eg. 'Press 1 for sales, 2 for billing or 3 to go directly to hold music'!). I am on sky superfast broadband and am unable to determine if I have internet calling or not (the voice light on my hub has never been on - but I have no issues making or receiving calls). The phone that I am using is a panasonic that supports DTMF. Do I need to buy a new phone or is this an issue with either my hub or my line? Any help would be much appreciated as i cannot find any solution anywhere on the web or community boards to my problem!!
Thanks in advance for any advice.
Re: DTMF issues
Is the handset cord plugged into the rear of the Sky Hub, or a socket on a wall box?
The former is internet calls, the latter is PSTN.
Cookiemonster13
Re: DTMF issues
Its plugged into a socket....does that mean that the dtmf tones should or shouldnt work??
Re: DTMF issues
@Cookiemonster13
That means you aren't currently using internet calling, and your handset is connected to the national analogue phone network.  Tones should work: if they don't then the issue may be with the handset or the PSTN 'line' but cannot be related to broadband or the Sky Hub.
