Discussion topic: Cut off from 3-9 pm
Message posted on 14 May 2025 09:08 AM
Cut off from 3-9 pm
Sky city off every day my service from 3-9 pm
Message posted on 14 May 2025 09:09 AM
Re: Cut off from 3-9 pm
Every they the cut off the service at the same time from 3-9 pm and they said I need I new router, Seriously
Message posted on 14 May 2025 09:10 AM
The Customer Service is not exist, they answer drafts
Message posted on 14 May 2025 09:11 AM
@Pda1965 I doubt Sky are cutting you off as you claim. There just would be any logical reason for them doing so.
Message posted on 14 May 2025 09:12 AM
They said no problems in your area and every day is at the same time, what do you think?
Message posted on 14 May 2025 09:21 AM
@Pda1965 If it happens at the same time every day then it suggests something locally is interferring with your service, it doesn't mean that Sky are cutting you off, there would be no reason why they would do so.
Message posted on 14 May 2025 10:56 AM
@Pda1965 You should just post the url that you are trying to get to at those times, unless it is your whole broadband that is off between those periods....
Message posted on 14 May 2025 11:12 AM
It's completely cut off you cannot connect, the router is without internet
Message posted on 14 May 2025 11:53 AM
@Pda1965 What hub do you have from sky, and what is also the service that you have purchased?
Message posted on 14 May 2025 11:57 AM
I don not think that this is relevant. The problem is suddenly is happening this week that every day at 3 till 9 I don't have any conexion, no internet, nothinat all and after that it's working nicely
Message posted on 14 May 2025 12:01 PM
@Pda1965 Just call sky then!
