3
This discussion topic has been answered Discussion topic: Correct router for Full Fibre 150
This message was authored by: JayJay64
I have FTTP full fibre 150 but have not had the router updated, it is still the original 4.2 SR203. Should this not have been updated as well
This message was authored by: JimM1 Answer
Re: Correct router for Full Fibre 150
@JayJay64 No the SR203 is well capable on a slow FF150 connection, Ethernet cable port4 WAN back off that sky hub to the Lan port on the ONT, that is all needed to be done, phone if used for landline plugged into the sky Hub now!
@JayJay64
It appears that Sky only supplies the Max Hub to existing customers who choose to add the WiFi Max subscription supplement.
Avatar for JayJay64
Thanks TimmyBGood.
