3
This discussion topic has been answered Discussion topic: Converting Max Hub router to 2.4 MhZ
This message was authored by: Emily1910
I have a new Sky Max Hub but apparently I need my wifi to be 2.4 for some of my appliances (smart plugs etc.) to connect. Any idea how I can do this on a step by step basis?? (I'm vaguely technically literate but not completely!!). Any assistance gratefully received!
Re: Converting Max Hub router to 2.4 MhZ
@Emily1910
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
@Emily1910
Avatar for Emily1910
Thanks, I'll give it a try...
Thank you... that worked!  (Although I still can't get the smart plug to connect.. but the wifi bit is right!)
