Discussion topic: Connection to Internet
This message was authored by: Zummerset
My Internet is down, my router light is green but fading off and on
This message was authored by: HL45
Re: Connection to Internet
Mine is doing the same
This message was authored by: Sophiedavy89
Same as mine. Suddenly went down but checks on here are saying it's fine when it's not.
This message was authored by: Elisha300
Same issue here, just resorted to dvds and going bed
This message was authored by: Lewis102
I'm getting issues aswell
This message was authored by: tiffypaigexx
Mine isnt working either
All,
At the time of night you've posted it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down after 7am use this link to check to see if there are any broadband problems or outages nearby.
