Discussion topic: No wifi router says its working ok
Message posted on 09 Jun 2025 10:56 PM
My Internet is not working and as I have stream the tv is off too. The tests say its working fine, white light on the router.
Any idea when it will be back working? I'm in Bournemouth and working from home this week
Message posted on 10 Jun 2025 05:03 AM
Re: No wifi router says its working ok
@Michaelm3
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
