Discussion topic: No wifi
Message posted on 10 Jun 2025 04:25 AM
No wifi
Message posted on 10 Jun 2025 05:00 AM
Re: No wifi
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still a problem after 0700 use this link to check to see if there are any broadband problems or outages nearby.
