Discussion topic: Connection keeps dropping
This message was authored by: Ygobradley
So for the past week or so our connection keeps dropping and it was at its worse yerster being off for a long period of time which doesn't help when working from home. We have tried unplugging everything and restarting and following the guides on the help pages but nothing seems to work. The Internet led with switch from green to Amber and stay like that. Any help would be amazing thanks
Re: Connection keeps dropping
@Ygobradley Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Avatar for Ygobradley
hello ive have tried running it a couple times, it tends to show as all green but ive had connection to hub be red once yesterday, but then once i retested it it went back to connecting.
It's just dropped again and sends me to connection has dropped page and the led is a very dull green now and not as bright as the power button
@Ygobradley I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat.
More information about this process can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent @Ygobradley an invite to chat.
